Help Quality of screen
Yui
Hey guys,
I just got my DHD yesterday night and played a bit with it in the morning. First thing I noticed was the quality of the screen, nothing is sharp other than the app icons, the weather widget, switch widget has a verry stuttery gradient and just seems less smooth. Is this a fault and should I get a refund or is this normal? Based on the screenshots in the show your screen threads, something is wrong with the screen.
Thanks
The DHD has a bigger screen as the Desire but the same resolution.
The DHD has no AMOLED screen like the Desire.
Therefore the screen of the DHD can't have such a brilliance as the Desire.
But not sharp?
On my DHD I only see a wonderful big display :)
Harry
Here is an image of such an example,
See the control widget, thats what I mean.
If you're refering to the Green and Purple circular lines you have on the power widget, thats a fault. Can you take a focused picture of the entire screen?
If it is faulty, we should be able to see if from a distance and from all angles.
I've just worked it out!!!
Its the reflection of his computer screen because he used a webcam to take the picture
:D
