Root ques about CM7 r2 Hboot
ashik666
i have updated my hboot to cm7 r2. but my internal memory was still showing 136mb left.i was supposed to get 287mb.then i moved my delvick cache to sd ext.it gave me like 80 mb of more storage and now i have like 220mb of internal memory. where is the rest of my internal memory? i did a flash a new rom after upgrading my hboot
Well if you've restored your apps and data you can't expect the internal storage to be empty. You've moved you dalvik cache, so I assume you have also moved your apks, but that still leaves app data (including your phone book, messages, etc) app caches, and app libraries (for those apps that have one) in internal. You are using about 47MB, and had enough apps to have an 80MB dalvik cache, which sounds reasonable to me.
If you want to know what's using the space, use a terminal, or a sufficiently capable file browser such as Root Explorer or ES File Explorer, and just have a look at the /data partition on your phone and see what is in there.
i actually wiped all my data before flashing the rom.and i didnt restore any data after that. so what could be the problem here that taking up the space?
