jdailey1981 Android Enthusiast Feb 10, 2010 #1 If you mark the apps on the ignore list, will that keep them from running or does it just not tell you if they are running or not.
OfTheDamned The Friendly Undead Feb 10, 2010 #2 I may be mistaken, but from what I understand from others the ignore list is for apps that you don't want to kill.
Podivin Android Expert Feb 10, 2010 #3 OTD is correct (naturally). If the app is on your ignore list, ATK will let it keep running.
pkopalek Android Expert Feb 10, 2010 #4 It's for ease of use. Apps on the ignore list a) Won't show up on the 'Running Apps' list that comes up when you open ATK b) Won't get killed when you push 'Kill All..'. You can remove them from the ignore list and kill them whenever you want.
