question about dolphin browser
Maxwell
Member
When using the stock browser, I am able to go to and see actual websites whereas using the dolphin browser, entering the same web addresses leads me to the mobile version of the website. I rather the actual website. I tried looking under the settings of the dolphin browser for a fix but to no avail... anyone with any ideas? Thanks in advance.
You can try this: go into Settings and change the User Agent from Android to Desktop.
Many of the mobile sites give the option to go to the actual site, normally the link is near the bottom. Once you do, especially if it is a site you visit often, add it to your bookmarks.
Thanks for the response guys... it is greatly appreciated. Going with doogald's advice, I was abled to view some websites as they are meant to be seen strangely enough while others are still in mobile form. I also took soul's advice about seaching out the link at the bottom of the page. That worked also. Thanks again.
