Question about footprints
Hello to all. I've been lurking for a couple of weeks now, and I must say there is a lot of good information on this board. Reading some of these posts has made my transition to the Hero much easier.
I have a question about Footprints. Is it possible to add places I've been historically, and not just places I am *now*? I'd love to be able to work with the file format, if such a thing is possible. Has anyone dissected the footprints.db file? And if not, what is involved in an import? Is that only for getting the data from another Android phone?
Hey,
I use footprints a lot. I was able to add locations by taking a print, then hit edit, then touch the map. A red pin should be showing now, and you can drag to a location on the map whereever you want.
Was not able to change the date though.
Hey,
Thanks, I can live without the date.
