Help Question about images taken with the Note 10.1
5tevie
Hi guys, Me again with another problem for you.
I need to take some pictures using the Galaxy Note 10.1 and I know how to do that. My problem if finding the easiest way to get the pictures from the Note to a Mac for posting on a forum.
Is it easier/quicker to hook up the Note to the Mac (it's a Mac Mini Aluminium using Snow Leopard) using the charge/connection lead or is it possible to store the images on a mini SD card? That would be the simpler option if it is doable 'cos what I need to do is take 5 pictures of the same object using 5 different cameras for a competition. If I could use the same SDHC card in each camera, that would be a bonus.
Any clues much appreciated.
Steve
I don't know what the sdcard capabilities of your Mac Mini are but I've found that the easiest way to export photos is through the Dropbox app. It can be set to automatically upload any photos taken and then you have access from any other device you've installed Dropbox on. Hope that helps.
I have that Dropbox jobbie on my Mac but I hardly ever (never) use it.
I'll give it a go and see what happens.
Ta very much.
