Please bare with me on this I am fairly new too rooting/flashing.
Basically I was thinking about rooting and flashing the InsertCoin ROM to my completely stock Desire
I have downloaded Unrevoked to root, so am I correct in thinking that in order to flash this Rom i do the following steps?
1.) Root using Unrevoked
2.) Partition my SD card as described on the thread with this ROM.
3.) Flash the ROM
Another question is I dont think I can change the HBOOT because I am a mac user so when it says "stock hboot" it means the one I am running now and that i need to download the InsertCoin Sense 2.1 1.0.8 A2SD from here Baadnwz's custom ROMs: stable (top post)
Any help would be appreciated.
3.) Flash the ROM
has a bootable cd, youll be fine if you want to. You are currently on a stock hboot, yep
