Question about memory card
mi04se1
I just purchased a 32 GB Sandisk card from Verizon for $99. My question is about transfering music. Instead of syncing my phone to the computer, I was just going to plug the card into my sd reader. If you transfer songs with artwork to the card, will the artwork show up on the music player?
It did for me. I go through iTunes and edit all info there. From there I get them off my hard drive and out them on my as card. Art work and all info from iTunes are on my captivate.
I used the usb cable to connect the phone to my laptop, and then used the drag and drop method and if the song or albums had artwork with them, they show up while playing the song.
