Help question about Note 3 call log settings
So I can't seem to find any info for this. I have a Note 3 with android 4.3. Every time I go into the call history it shows a history of all calls and text messages. I can go in and change the filter to all calls and then it doesn't show to texts but can't seem to find a way to keep it that way, I have to do it every time I open the history. I want it to default to calls only when I open my history, and not show the text message history as well. Does anyone know if/where I might be able to do this?
Thanks in advance ^_^
Same here, I only see all calls. I have to change the view to see everything. Maybe it is specific to your version? I have AT&T
i have the same problem too.. I see all the calls and the sms... if I change it it seems to be only a temp change... any help is greatly appreciated.!!!
