Terabethia
Android Expert
So I finally ordered a Phantom and put it on last night. It was pretty simple, took about 20 minutes because I had to pull it up and redo it because of 2 bubbles I couldn't get out. Next attempt went flawlessly.
It's been sitting now for 12 hours and I still see moisture under the skin. I have read some posts and it appears that it may take up to 2 days to completely dry. Which sucks because I didn't have this problem with Zagg (my fiance just put Zagg on his Dinc and it was done and perfect after 4 hours or so).
But before I pull this thing off I want to make sure that this really will go away in another 36 hours. Its very noticiable and bugging the crap out of me, but I will be patient if you guys think it's worth it. I do like it better than the Zagg, there is almost no friction.
FYI... Don't know if it matters but I didn't add any soap to the water cause I didn't think I would have any problems with placement (which I didn't).
If this doesn't work I am going to order a Steinheil CC and see how that does. If that doesn't work either I will just go back to Zagg. It does look great on my fiance's phone and I used it for 2 years on my Dare so I know it works. I was just hoping for a less tacky alternative for this phone.
Guess I will be patient and see if it's cleared up by tomorrow.
And it's not like it's getting better so I know that in another day or two it will be all dryed up, it's the exact same amount of moisture that was there right after I installed it. It hasn't improved even a little bit in 36 hours...
