I installed the radio update tonight while running Velocity 0.3 with the GNM Turbo 4 OC kernel and was wondering if I restore back to a previous state (like just before I installed the radio update) would I lose that radio update or is it like flashing BIOS on a computer (it just stays up to date as long as you keep it up to date).
Example would be setting a restore point in Windows, flashing the BIOS to a newer version, rebooting, then restoring Windows before you flashed the BIOS. The BIOS is still the most up to date version even though you restored Windows to a previous state.
Does this work for radio update?
