For some reason my phone reception has gotten very bad. I used to get at least a couple bars at home and now I am lucky to get one bar...it's usually no bars. The power button is also sticking.
Rom's shouldn't affect signal, do they?
I took it to my dealer and they recommended returning it to corporate store to return it since it is still less than a year old and covered under warranty.
I know that I should revert to Metro PCS original ROM but I have two questions.
If I return to factory settings it will be version 2.2.2 and I originally had 2.2.1. Does this matter? Second question is do I need to format the SD card since I partitioned it? If so what would be the procedure for this?
Thanks
Thanks
