Help Question about S2 and AT&T
Hello everyone, sorry if anyone had already made a thread like this...
So, I'm from Brazil and just got to the US and i'm going to stay here for a year.
I was thinking in buying a smartphone, and since the galaxy S2 looks like the best one around, that is my main choice.
The problem is: I heard AT&T made these 1 year plans here in the US, but after it finishes and I go back to Brazil, I won't be able to use it there, with my old SIM chip.
Anyone knows if that is true?
Or is there anything I can do to be able to use it here in the US and back in Brazil?
im pretty sure you just need a sim card to be able to use it, assuming youre on a GSM network in brazil. someone may want to make sure but i think you should be fine
If you get an AT&T model GS2, I don't believe it will work back in Brazil unless it is unlocked beforehand, once unlocked it should be fine/or you can get an International model which will already be GSM unlocked.
