veg-0-matic
Member
I have a 16Gb SD card that I want to use with my Triumph when I finally get it. I figured the easiest way to do it is to install the card before even activating the phone. My question is, are there files on the pre-installed 2Gb card that I need to transfer to the 16 card first?
Or should I activate the phone first and then install the bigger card?
TIA!
TIA!
