Root Question? About soft key mod
Pic
Can this work on the admire, I've tried fiddling with the build prop but it didn't work
Code:
qemu.hw.mainkeys=0
you're talking about adding this line to the build.prop? someone asked this in the LG Motion, if it would work for GB and it doesnt. it it did, it would be helpful to some
Code:
qemu.hw.mainkeys=0
Yeah I tried that line but it didn't work...:(
Im not sure if the same line is used on GB phones that have soft keys but i would try getting in contact with someone who has a GB phone where the soft keys are native and have them look in the build.prop for the line. if its the same then probably we cant get the soft keys but if its different than there might be hope
Does the admire even have these png's loaded into the framework? That would be a good starting point there. If so, then there may me some code editing to do in services.jar
Can you give a try ... I have no idea on how to do that
Oh... lol I hate that part...(coding :banghead:
tell me about it, i cant seem to code these extended powermenu mods right. it would really help if had a proper guide to follow that was meant for GB. im so close to giving up on the mods.
if not then ill just do it the cheap way and take the android.policy from an existing rom that has the mod working. . . but i dont want to that Dx
Lol true true
