So when I go to partial wake usage, and I see the top offenders, in my case Facebook, then android system and voicemail. What do I do to prevent these from sucking battery? I turned my notifications off in Facebook, anything else I can do?
How much time does it show it held wake locks? Being at the top of the list doesn't mean much unless it's a high percentage of total uptime. If it is, does it do it all the time, even when you reboot?
That might be a *little* high, but it's not something I'd worry about. It's probably caused by notifications (common with such apps). Did it go up much since you turned off notifications?
no since I think it was at 8mins before, and since I turned the notifications off it only went up to 10 mins. The next in line was android system at 2mins,
and I actually have been unplugged for about 3.5 hours I just realized
