Question about spelling auto-correction
Mubble
On my old Blackberry I could programme the dictionary to change certain letter combos in to the correct words. Kind of like - "helo" > "hello".
As this was user programmable, it was also useful for including things like - "hl" > "hello mate".
On to my point. I write " I'll " a lot but get annoyed sticking the apostrophe in. If I write it without the apostrophe, it's just the word "ill" so it doesn't change it to "i'll". On my Blackberry I made "il" become "I'll".
Can you do this on the Desire?
Or, if I type " il " and keep selecting " I'll " from the suggested spellings, will the dictionary eventually change its default suggestion?
Try Swiftkey. It works amazing. keeps learning with every message/email you type. also your history of sms messages. It does amazing auto correct and suggestions based on your history. If I type H, it get offered Hi. If I type my name, I get offered both my surname and "& xxxxx" (my wife's name). best keyboard app yet.
Just installed swiftkey. I like it. Definitely helps learn the words I use which makes it what I wanted. Thanks. I can type "il" and after a while of selecting "I'll" it's now become the 'spacebar' default suggestion. Will take some getting use to though as I'm not used to it already knowing what I want to type before even I do!
I use the hardware keyboard (on my G2) and it already does "il" to "I'll" and several others. I really want it to change "id" to "I'd" but can't find where to set that up. Anybody know?
