Question about synching Tablet, Phone, and PC
I just got a Samsung Galaxy Tab (8.9) for Christmas. I already have an EVO shift (owned by me) and a Lenovo Notebook (provided by the company I work for).
I have HTC Sync running on my notebook to sync my outlook calendar with my phone. Unfortunately the company I work for has strict connectivity rules and I can only sync my phone with my notebook using a USB cable, but it is working to my satisfaction.
Now, I want to sync my tablet with either my phone calendar or my outlook calendar - I don't care which, I just want all 3 calendars to match. The problem is I am finding all sorts of apps which will sync Google/Gmail Calendar between my phone and tablet, but that is not going to work for me.
On my phone, the calendar I use to set up appointments is set to the "PC Sync" calendar - that is where I have to leave it set in order for my appointments to show up on my outlook calendar.
What application can I use on the tablet that will sync with the "PC Sync" calendar on my phone? I would like the synchronization to be managed between my tablet and my phone (not between my tablet and notebook) so that I can take advantage of their bluetooth connectivity.
Is this possible?
Thanks in advance!
Jill
Hello, have you looked at MyPhoneExplorer? It's an app you install on the phone/tablet and your PC and is generally a pretty good sync solution. I stopped using HTC Sync a while back and have been using MPE since.
Ok, i tried mpe and it does not do what I need it to do. Mpe will sync various handsets (phone & tablet) with a client device (notebook), but i need to sync 2 different calendars between handsets (tablet and phone).
In summary I need to sync google calendar with the pc sync calendar (from my phone) so that google calendar will display all my events on my tablet.
I want my phone to be the master, and to sync all its events with my tablet.
Is this possible?
