Accessories Question about the extended battery
CrimsonToker
Android Expert
I found one for the volt online, brand name is Sporting Persistence. The capacity is 2960 mAh, but the stock battery is 3000. I don't know much about batteries but I would think 3000 mAh would be the longer lasting one. Am I understanding it wrong?
The higher the mAh the more battery life you get. So the stock battery would be better than the battery you are looking at by just a little bit. Make sure you get a good brand battery as some of the cheapy one don't perform as they should.
Probably won't either. When I was looking for extended batteries for my S2, the highest I could find was double, 2800mAh.
