I am currently downloading, do not turn off target....how long does it take to download? It has been at least 45 minutes.
OK....I just clicked it....it is showing the progress bar now....Are you downloading the update from Kies Mini? If so it should tell you the progress of how much has been done.
...thanks!!
You don't need to remove your SIM card. Backup anything you don't want to lose. Also, follow these instructions very carefully. Goodluck!
How Do I Update The Software On My AT&T SGH-i897 (Captivate) Phone To Android 2.2 (Froyo) Through Kies Mini For PC?
I have followed these instructions to the letter. I keep getting a window crash on both my laptop and destop computers. Is there another way to get this update with Kies Mini? Hell, so I just go into AT&T and have them do it.![]()
Yeah if all else fails try AT&T.
If you are following the instructions and your comp or phone is crashing then maybe you should just not update it, since that could mean that there is a deeper problem and you'd just be pushing the phone and comp further.
