frenchy714
Android Expert
I'm using Myn Warm TwoPointTwo. Does Sprint's Wifi Hot Spot work for free on this ROM?? And if so, how can we use their hot spot through this ROM w/o being charged? Thanks in advance!
Awesome! So just so I'm clear, w/ this ROM you don't need wifi tether and you can use Sprint's Hot Spot for free? Would you happen to know how it's possible to use Sprint's Hot Spot w/o getting charged?
I have yet to be able to actually browse the web using the Sprint HotSpot with Warm. I can connect devices no problem but they can never actually get out to the web.
I haven't tried it with RLS3 yet.
But, yeah, I know other folks are getting it to work without issue.
I don't know how it's getting done. I consider it like sausage-making. I don't wanna know how it gets made. I just want it to taste good.![]()
make sure you can access superuser, and tell it to always accept![]()
