i believe Z has the camera semi-working but still playing with it before he releases the fix for it so it could be out there soon. not sure what other bugs it has, i only put it back on my phone in a serious way yesterday and so far i've had no issues at all.
i'm pretty sure its installed directly on the phone, it installs the same way as any other rom in xrecovery and with root explorer i can access the files installed on the phone, not just the SD card so i would say thats not true.I've now been told that 2.2 runs on the SD card as it thinks its the phones memory. That's something else i'd rather give a miss.
I think i'll wait until 100% working out of BETA
I'm now using Eminence and JIT Enabler 2.0, which gives me a benchmark of 807
i think the first release of it was done on the sd card and you could dual boot it but the current one is a direct phone rom.
i've been on it for a couple of days, no issues but still waiting on the camera being sorted out.
How much extra work is it to have the ROM be a dual boot(2.2 and 2.1)? I know one of the early beta's was dual boot and that would allow for people to have quicker access to their camera.
I believe that the only reason dual boot was possible, was because the 2.2 alpha was installed only to the SD card.
But here is what I do.
1) Boot xRecovery
2) Go to backup/restore
3) Choose Backup and wait for the backup to complete
4) On your SD Card, locate to xrecovery/backup and rename your backup to something you will remember.
5) Now you can wipe the phone and install whichever other ROM you want.
Setup your new ROM with all your contacts, apps, etc.
6) When you want to go back to your original ROM that you had in the first place, follow steps 1 to 4 above to backup your new ROM
7) Then wipe your phone in xrecovery again, and go to backup/restore, choose restore, and choose the folder you backed up earlier
8) Now your phone will be back to the way it was before you wiped it in the first place.
That is what I do and its very quick, and easy to do![]()
I'll just wait either for a new dual boot or for the camera to work on 2.2.All things considered that is very quick and easy, but for someone that uses his camera a lot especially with a new puppy in the house... that won't be convenient for meI'll just wait either for a new dual boot or for the camera to work on 2.2.
The same reason I won't keep 2.2 installed. I have a newborn baby so you can imagine how often I use the camera lol
Hey congrats... I'll be having one of those in June![]()
