Root Question abt Rooting Samsung Galaxy Prevail 2.3.6
I tried using the one-click method program but it didn't work.
Is 2.3.6 too updated? If so, how do I revert to an earlier version?
Thanks.
Thanks.
use odin..revert to ej06 or updated fa19 with root and cwm preinstalled
http://androidforums.com/showthread.php?p=2953252
Factory reset?
Settings> Privacy> Factory Data Reset.
Erases everything and start from scratch. You could also use the latest CTMod rom and it has extsd capabilities... Someone with more brains can explain it to you. They should be along shortly.
:mad:I need more space in my phone, I want to erase all app that I don't need in my samsung prevail 2.3.6, can somebody help me?
Odin (Return phone to Stock/Factory) updated 02/23 new FA19 image
This will help you. Also try using Titanium Backup (you have to have root) and links2sd to move the apps to the sd card.....:listen:
I used this one and watched the video so I wouldn't get it wrong !!!!!!
DOWNLOAD FA19 Gingerbread Rooted Image with CWM5 by Koumajutsu
