Root question: apps, memory, SD card
51kbos
Hi,
I searched through other similar threads, but couldn't find what I wanted to know.
I have a rooted Huawei Mercury running 2.3.6 and I've noticed that apps installed on the SD will still have data in the internal memory, I have a 16 gig card that I've installed all my user apps to but still have internal memory issue. how can you free up that memory those apps on SD card are using?
Link2SD requires you to Partition your SD card and I'm not exactly comfortable doing that.
Or with flashing a ROM
Is there any other way to move that remnant data to the SD?
Please keep in mind my skill level is probably just above that of your average user, I don't know a bunch but I can follow instructions if they're concise and clear.
