Question - Battery usage indicator?
Hi all...
I have a question about the battery usage indicator on my OE. I can't seem to find it anywhere. When pull up the 'battery use' icon, I see the percentages of the apps consuming battery capacity and the time the phone is been on in hours/minutes, but can't find the actual battery use percentage (i.e. 40%, 50%, etc.). Where do I find that, or how do I access it? My phone is stock, not rooted.
Thanks in advance. Great forum, btw!
If it's something that you want to have on your desktop or status bar, there are a lot of good battery apps that you can use. Personally I would suggest Power Toggles.
