Question for steslatt
Shotgun84
Extreme Android User
I flashed Villainrom 2.4 yesterday and then flashed the updated ninphetamine 2.0.5 kernel. After that I would get a force close message every couple of minutes, but after pressing force close the phone carried on as normal and didn't close anything. So I got feed up with this after a few hours and flashed back to 2.3.
I have just noticed you are running the same rom and kernel, so was wondering if you had the same problem and found a way round it.
Was it com.android.phone? If so then this is the dialer. Try clearing the data for the dialer app in manage applications. Not sure if it will delete contacts though so make sure you have a backup just in case.
No joy on that one. Tried everything I can think of but my phones just not having it. I suppose no biggy 2.3's good anyway. I will just wait till 2.5
Yeah. I've been reluctant to do that ass I've had a few problems with the market recognising alot of my apps when I reinstall them.
Fixing permissions didn't work. Anyway I did a full wipe and its flashed with no problems. Now I have a fun few days re-downloading most of my apps as even though I backed them up with titanium and google most of them don't show up in my apps list on the market, so I can't update them when needed.
this is probably kinda late, but after a restore with titanium, reboot ur phone.. i was completely disappointed with titanium after i restored.. til i rebooted. everything was exactly like it was pre-wipe :D
