Root [Question]NO PC Required Root?
I will upload and root stock backup I think that the way to root without PC but people need to learn how to flash recovery from fastboot the way if you don't have root you can flash from fastboot and then use the backup is a clean one no account just download in the phone and then restore
Dadcup I just smoked 2 mean L's last night so can you dumb that down for me until my developers lingo makes its way back into my head... :-)
Sent from my ZTE N9120 using Tapatalk 4 Beta
I will soon I get back from work to night my internet was bad for a storm now I think is fix I let you know to night OK
**Bump**
I'd like to enquire about this topic also. I have not seen anything on it, but in dire need of it.
Not looking like there is. Is it possible for someone to post a backup and it be pre rooted or any files that can be manually replaced? I have no quick access to PC. :-(
But ya need root to install recovery though, right?
No not always. Depending on the bootloader and model, make, ect. Some androids have a factory version of cwm but it usually cant flash anything besides factory images or su update so b careful. Remember debuging and good luck. Ive tryed z4, framaroot, master root, towel root, iroot, and 1click but still nothing.
