Accessories Question on a case.
billy345
I have a dx and the case has a magnet and sometimes when I pull it out it is in the dock screen. Battery life if fine but will this hurt it?
phaz
If the screen turns on then your battery life will tank.
Guess you have to turn the phone 180
Find another solution, but don't put the phone in screen out. More susceptible to damage to the screen. There are apps that will render the magnets useless. Might be a solution for you. Forget what they're called.
