Root question on flashing/removing themes.
cheluz245
Running on #2 by Ldrifta (It's the ISH by the way)..
I flashed Evirus theme over it, then cleared cache and dalvik, flashed Cyan theme.
My question is, now when I press the home screen I get the option to select LG launcher and LauncherPRO. If I select LG Launcher it goes back to Evirus icons and theme mixed with Cyan theme.
To get rid of both, would it be best to re-flash the rom? or is there another way of getting rid of the two themes?
He themed more icons then I did. Really only sensible way is to use a launcher theme. You could reflash But...youll have #2 icons still too because again ldrfita themed more icons then I did.
Thanks for the reply Shiny. I think i'll just flash the Rom again. =P I like having my things nice and clean of mods I didn't like. Flashing the theme also cleared my contacts. =\ Not sure if that's right or not. Any how, thanks.
Cyan 4 2 wiped your contacts??? I have no clue how it would unless you wiped data. I dont have it set to wipe data or else it'd wipe all your apps too.
