Not really noticed but it is always flashing wheni wake up in the morning
Sorry if this is a hijack, but seems like a good thread.
Does the notification light support multiple colors? Unlimited colors? I know my Droid X can display a large amount of colors and apps can each have different colors, but the HTC One S I have has a couple of colors, but seems like apps only can make it display one color.
How's the S3 work?
Tbolt didn't stop, just took a break. It starts up again and stops again in intervals.Does the notification light keep flashing until the event is checked on the galaxy s3? On my og droid the light would keep flashing until i checked the event, but on my thunderbolt it stops flashing after 5 to 10 minutes even if i don't check the event.
Mine would start up again every five or ten minutes till I checked it. 'Course I was rooted and rommed, so maybe it was different.Mine would stop and never start up again.
Does it work for S3?Guys use the app Light Flow - you can configure it per notification type - colour, how long it lasts, whether there is vibration, whether there is sound, whether the notifications repeats at an interval, what hours you don't want the LED on for notifications. Brilliant.
Wouldn't be suggesting it if it didn't.
How do stacked notifications work? If I set a text message to flash green and Facebook to flash blue, and I received a text then a wall post, would it only flash blue?
I'm going to try it out anyway just curious!
It cycles through the colours, on the free version it changes every 20 seconds, on the paid version it's 2/3 seconds.
If I use the LED for charging, I'm afraid I'll burn out the bulb if I over use it or something of that sort...
is that a valid concern? thanks
I know people have suggested getting Light Flow. However, shouldn't the stock notification light work? When I get a gmail email, I do not get any lights at all. Also, I have selected a blue led light for new whatsapp messages, but it would only show a solid red when I do get a message.
Is Gmail not compatible with the S3 LED lights?
http://forum.xda-developers.com/archive/index.php/t-1198825.html
Tasker can make use of this notification light as well. There are a number of things you can do with it.
Lightflow does not work on the US/Canadian versions.
Not sure if this is correct. I got an email from the developer with a chart that shows what actual colors do light up. I am sure the dev is working hard to get it right. The S3 North American represents many sales.
