usedtobeanyer
Member
For the weather icon that appears on the home screen, does anyone know if the high/low temps are the forecast high/lows for the day or the actual high/lows? Thanks.
You sure ? Can't the forecasted high/low temps be adjusted as the day goes on ?...the high/low temps reported on the app change with each update (the little plus sign on the left of the bar) therefore they would have to be the actual high and low temps "so far" in the day.
Otherwise, put in the same location at Accuweather (??) and see if things match.
. lol.. ..simply tap the word weather on the bottom bar and it will take you to AccuWeather's site. You can then put in a zipcode or select a city.
