Help question on "unclogging"
I'm new to my inspire from a blackberry torch and i was wondering if there was a way to make native apps that I won't use disappear or at least move to a folder where they won't be in the way. On that point can I "folder" media type apps(camera, video camera). Anything to clean up my phone and keep it more organized. Thanks
I use launcher pro which has a hidden app draw feature so I can hide the apps that I never use (att bloatware). I'm not sure how to do that on sense or if its even possible without rooting the phone
Yeah I did see quite a bit written about Launcher. Almost reminds me of quicklauncer for bb if your familiar with that, but I'm not too familiar with the whole rooting concept and since i'm new to android i'm not sure that's something i would like to venture into but thanks for the launcher heads up
I have never used a bb. But launcher pro plus just got an update and now has a bunch of different skins available for the widgets, including an available sense theme for like $1.50. Launcher pro plus is only like $3 but IMO is well worth it. If you go with another launcher whether its launcher pro, adw or go make sure you also get home switcher for froyo, this will allow you to go between sense and your new launcher if you need to.
