I use the stock weather widget on my home screen. A week ago there was also a small calender showing on the widget, but now it is gone. Does anyone know what may have happened to it?
It only shows on a few certain events. If you open the widget and go to settings you will see options to enable/disable them. I don't think you can edit or add events though.
