Root QUestion regarding BB (in ROM Manager)
emdmao
I couldn't find the thread that mentioned this awhile back, but, the baseband update listed under BB section in ROM Manager, does that update the last two baseband leaks?
I remember the .41 had to be done before the .43 (i think those were the numbers) but with this download do I need to install the other one also?
Pete's update listed under the BB section in ROM Manager applies .43 without the need to apply .41 first. It's an all-in-one.
You can also find the older updates in ROM Manager if you poke around. I just downgraded because the updates didn't work as well for me as they did for others. YMMV.
