My wife has a Wildfire S with limited data allowance on the contract so all syncing with google mail and the calander etc is switched off. Is there any way to enable the phone to sync when connected to our home (or any) wireless network only?
Just leave syncing on, and turn off the 3g radio when you are not at home, and turn on wifi when you are at home. If the 3g radio is off, nothing will sync or connect when you are on the go.
I am about to purchase a HTS Wildfire S and would like to know if I am able to sync it with ical on my MacBook. If ppossible, does anyone have the software for it how do I go about accessing the software
I use the app Unlock With WiFi, which can be set to only sync when connected to WiFi. It is a great app. The phone automatically unlocks when you are at home. The only problem is that you must have at least 15mb of memory left for sync to work.
