jmichael37
I'm trying to get everything set up with 2.2.1 and just going through some things and after doing a little research, you apparently have to pay per month for the 3g mobile hotspot app (which is ridiculous in itself, nvm the fact that apparently the ally isn't supported either through vzw). Anyway, I did read of a workaround for it by using lgservicemenu, but I was actually wondering if other wireless tethering apps would still work or not, AND, if they do, good old verizon isn't going to force any charges will they? It's not something I use all that often, there is times it's convenient, but I just want to try and clear this up for myself and anyone else who may use hotspot. Regardless, thanks for your time.
And also as a side note I'm using rooted froyo per tridents guide--exceptional work!!! donations will be made
