Question(s) about Factory Reset
Will doing a factory reset put the phone back to 2.0 or will it stay at 2.0.1?
If it goes back to 2.0, how long does it typically take for the Droid to update to 2.0.1?
Will removing the SD card ensure that my photos and music and such are left untouched?
Thanks, everyone!
when i got my replacement droid it asked me if i wanted to update to 2.0.1 right after it was activated
Factory reset does not erase anything or take away updates. It merely resets all your customize settings that you did and sets them back to the original settings from the factory. You will have to recustomize your phone. Factory reset is used when you screw things up in the settings and can not figure out how to correct it or what exactly you did.
