I'm running Playful's CM7 with the CPU governor set to performance and Minimun CPU clock at 633 and Max. CPU clock at 710. No issues so far, nor do I feel it overly warm. Haven't tried any YouTube videos or anything too CPU intensive, but so far no crashes or reboots so I'm good.
Toke tested it out @32 and said it was good there.BUMP anyone know the vm heapsize i should use for a stock rom?
Best way is to try n see which settings work for you as your phone my differ for others. For min I would set it @245Mhz, max 710 will prolly work fine.Ok im now running CM7 what can i use for max and min settings on that and should i keep the heapsize at 32?
I have cm7.2 on my m835 and my wifi and camera is not working. what can I do to fix this?
Uh, am I missing something? Since when has the m835 been overclockable? and HOW!? WTF?
.flashing ideos u8150 kernels is how i got a2sd,oc, multitouch n wifi tethering working
my particular device was stable @729, but could go up to 800+ b4 boot looping
