Help Questions about app brain and resync
Jayme
If I do a factory reset and then resync with app brain, Will the apps I resync have the updated apps or the orginal apps. There are a few updates that I DO NOT want.
thanks
I'm pretty sure AppBrain just lines up the installs in the Marketplace for you. Therefore, I believe you would get the most recent versions of the apps. I'm not an expert, though.
You're right. I have used appbrain, it remembers what apps you have loaded. When you reset and get appbrain again, it shows all the apps you had previously had. When you go to sync again, it just directs you to the direct market link without having to search every app you had. Then you install manually as if you had searched the app. You'd be getting the newest most updated version of that app.
