Help Questions about customizing Nuance Voice Command
Johnny Cakes
Is Nuance customizable?
I don't want it to ask me, "Did you say Call Joe"
My previous Nokia phone would just say, "Calling Joe." If it was wrong (1% of the time), then I'd disconnect. Why drag this out into a two-step process? Is there a "no confirm" setting somewhere in Nuance?
Is it possible for Nuance not to say, "Say a Command." I know what to do and, unless I turn down the volume, it is annoying to others. Can this be bypassed?
If Nuance is not customizable for making calls, are there replacement apps? Suggestions?
If you reach the main menu where it asks for you to say a command, you can hit the menu button and click on the settings tab. Once in the settings tab go into confirmation and click on never confirm.
check "TopVoiceControl" app, it's better IMO (but not as good as MSVC).
Voice recognition just ain't there on the android yet. I'm hoping with 2.0 and more devices out there it'll get pushed forward, plus 2.0 will formally release BT apis so you could potentially voice dial from headset.
EXACTLY what I was looking for (that also let me find the voice trainer :))
Thanks!
Bringing this one back up....any other suggestions to compare to MSVC?
