JuniorNA
Hey all. I must say LP is kinda cool, gives you a different feel of the phone. Right now i'm only using one screen, and 1 dock (not multiple dock screens), but i guess i'm just trying to find out if this is actually any different than the normal senseUI. I see there are limited icons, and we can either use the LP icons, or the default icons, but maybe there is an expansion pack for LP that i'm not understanding?
Also, what are you guys using as a clock. With LP, i can only add the analog clock, or other wigdet clocks i've downloaded, but can't load 10 clocks that came with the phone. I'm assuming those are senseUI clocks, and will not work with LP. Should i download clock widgets that will work with LP?
Also, since i'm only using 1 screen, and 1 dock, and i really not utilizing LP to the max here ? I should be using the dock more, and using it for more applications to quickly pull up right?
Does anyone have any advice on how to customize it a little bit to make the experience more enjoyable, or make it worth the while ?
Also, battery life? Any difference? Is it the same? I have ATK that i run every once in a while to kill some buggy apps/games, I noticed that LP is running and taking up a good amount of resources, has anyone reported a really bad battery due to LP being installed?
