Root Questions about rooting.
U
UrbanMuppet
Guest
No longer a contributing member. Account pending for deletion.
1)it is the recovery os
2)flash stock roms back on
3) not sure on that one to make a backup i beleave you need nand which requires root?
4)yes use titanium backup or mybackup (mybackup doesn't need su)
5)that is something you need to read each rom has it's own set of issues if any the major ones though are
Froyo 2.2 has camera issues
and radio and wimax needs to be flashed to some roms
if i missed something please correct but thats what i know
I'm an advanced computer user, run Windows 2003 Enterprise/Cent OS webservers, programming, dual boot arch linux/windows and more. I've been thinking about rooting due to the flexibility that it offers, getting rid of apps I don't want from stock rom and managing start up tasks and more. I do have a few questions and I've been searching with not a lot of answers.
  1. What is NAND Backup?
  2. How do I revert to stock rom if I don't enjoy root?
  3. Can I make a full backup of the ROM/SD Card to do a restore like I never rooted?
  4. Can I restore current app data so I don't have to start from *scratch* on my device?
  5. Any major limitations/bugs with roms right now?
I have a few more questions, but I can't think of them right now. I was thinking of holding out on root, but I'm impatient and love to push my devices to the limits to get the full potential.
1. Full back up of your current ROM. This comes in handy if you need to restore to a previous state after messing something up.
2. To revert to full stock, just run the RUU while HTC Sync is running.
3. No, in order to do a full backup/restore you need to have nand unlocked, therefore restoring from nand will always bring you back to a rooted version of the ROM. Run RUU for full stock.
4. Yes, I used Titanium Backup but there are also others.
5. Currently only with FroYo roms but this is temporary.
Never rooted a phone before, so I'll be doing some more research on the process. I'm already tired of my Evo and want to push more out of it. :D
What firmware are you on?
Simple Root is probably the easiest way to get full root.
