Hi everyone. I
^Mine placed me within 10ft inside a concrete bottom floor apartment, I'd say it works pretty well.
I'm inside a metal building with 1" walls and can't find anything.
The stock charge cable is very very short. It's a AC/USB adapter with a proprietary USB/ dataport cable. I tried using a USB 'extension' cable with it and it doesn't recognize it's charging..
There are 2 kinds of "GPS"- TRUE GPS you must have a clear view of the sky, the GPS satellite signal is not that strong to go through buildings, heavy trees, etc... Most phones use the celltowers to triangulate where they are. This is not as accurate, but is faster since the cellphone picks that signal up and is able to calculate much easier without using as much time from the satellites.
The GPS on the Transformer is NOT "celltower", not sure if it would even lock onto the satellites inside the car. And most nav apps have to have some sort of online connection to "update" as you're driving.
I found a free map program that you can Download the maps for offline use, but it's map only, no Nav.
Just to clear things up a bit.....
There is GPS and A-GPS (assisted). Most smartphones have A-GPS which you can think of as 'enhanced' GPS. An A-GPS receiver has an extra component that pulls ephemeris data off the mobile network. This allows for a quick location fix, and allows for rough positioning inside buildings, tunnels, etc. Most A-GPS receivers (in modern day smartphones, anyway) are 'true' GPS receivers in that you can lose the cell signal and still pull a location fix from the sat signals under open sky, or near windows indoors (just like your Garmin or TomTom). The TF has a 'traditional' GPS receiver (not assisted) as there is no cellular modem in the TF (although future TF's will likely have a 3G option, and thus may have A-GPS). Thus the TF requires you to be near windows when indoors, or ideally under open sky for an accurate position.
Yes, the TF will get a sat lock inside a car (why wouldn't it?) in the same way your Garmin will. Multiple Youtube videos on this.
No, most (commercial grade) Nav apps don't require you to be online to navigate, as they have map data that you download and install to your SD card. I use CoPilot ($5) for offline use, as a backup to GMN.
Thank you all for informative replies. I really like to have this tablet but it is not available in Iceland yet so I
It is an adaptable plug, at least the manual says it is.
I was extremely disappointed to find I couldnt use a USB extension cable on mine as well. Especially with a 110 year old house that doesn't have many outlets. That is stupid how short the extension cable is.
Are there any universal car mounts out there that the transformer fits in?
@Eris1981It is an adaptable plug, at least the manual says it is.
@Eris1981
All you need is a USB 3 (!) extension cable, this will work.
