ethood1999
My family thinks it will be better for us to switch to MetroPCS because it's cheaper so I have a few question:
1. In general, would you recommend this phone? I am coming from a basic phone, Motorola Rival which I hate with a burning passion. If something can run apps, text, call, etc. then I'm good with it.
2. How is the battery life on this phone? This is the #1 complaint I hear for every smartphone. In your opinion, how is the battery life? It's not going to be my #1 source for internet or stuff like that but I will be using it occasionally. Can it live off of 1 charge/night?
3. (in general, about MetroPCS) How good is the coverage? I live in the Philadelphia area and according to the MetroPCS coverage map on their website, my area should be good. We don't travel, at least we won't until at least Spring Break, so leaving the area isn't a problem. My mom works in the Trenton (Central Jersey) area though and she's wondering if the coverage would be good there too. We're coming from Verizon which has amazing coverage so this is why this question is important for us.
EDIT: I forgot one question.
4. I love Music. Does the phone come with some sort of USB cable that I can plug into my computer and transfer already downloaded .mp3 files from my PC to my phone? Also, is there some sort of dedicated-Music app pre-loaded? Can I play music on it while on some other app and/or my home screen(s)?
EDIT2: Forgot another question.
5. The phone runs like a normal Android, right? I can still access the Android App Store? I was confused as to whether or not the MetroPCS App Store or whatever overran the Android App Store or if they were both available.
