Root Questions on Backups
imSHAD
Alright well today i was going to flash Black Plague's Kernal over RN2 and compare battery life. After I made a backup I changed the name of the backup to RN2 and apparently changing backup folder names makes it so the backup is impossible... this is common knowledge but i didn't know this.
Any other restrictions to backups? (change folder areas, move whole folder to computer, etc.?)
You can change the name. I do it all the time. The folder has a name of a 1970 date by default so it's hard to tell them apart without changing their names.
Then why on all the backups i rename it gives me the Md5 mismatch error when i try to recover it? does it matter which version of CWM i use?
I have v5.8.3.1 touch version
i have a question myself about backups i would like to know if it is possible to make a back up of my LG Connect 4G without rooting it first? and how can i do it if it is possible? i would like to have a Original backup of my system un-root in case i have to get a replacement one day i can restore to that one and i would not have root on it.
There isn't a way that I know of without root. But you ain't got to worry. We have official firmwares that you can flash via kdz that takes you completely back to stock. Root away.
edit: here. http://androidforums.com/connect-4g-all-things-root/608218-official-connect-ms840zva-firmware.html
Exactly as Airtioteclint said, or if you're super paranoid you can
1.root phone
2.make backup immediately
Then if need to return phone
1.restore 1st backup
2. un-root phone
I dunno. Maybe the trick is to make your backups through ROM manager. That's how I usually do it & I haven't had any problems naming them myself & restoring them. I used to have the touch version too, but I switched to the non - touch one.
