hi guys, i have a question re the whole process..i used unrevoked to root my desire n used adamg's froyo sense w/o partitioning d sd card..upon boot up to the rom, i noticed that the internal storage has the same storage space left of about only 20mb which is basically the same as with the original rom..
i now used rom manager n partioned my sd card 512mb for both ext n swap file..n upon restarting, it now has an internal mem of more than 120mb..
so my questions are:
1. Are my partitioning settings correct? 512mb for both ext and swap files? If not, what should be the ideal setings and can please someone explain what ext n swap files are and what they are for?
2. Since I partitioned the drive 'after' installing the froyo sense by adamg, do i need to reflash the rom again?
3. I noticed that after installing a number of apps from Market, it comes to a point that it's stuck at 'starting to download'..only after i deleted some other apps do i notice that i can download addtl apps again..is this because of the method i did in installing the new rom?
Hope someone can clarify these issues..thanks in advanced!
512mb is enough for pretty much any applications.
