Questions...
Y3TZ
Got the Bionic and I am enjoying it so far. Couple of questions for people who have had and Android longer than I have, which is for 4 days now.
1. For the first day after setting up the WiFi, the data widget would say something like "wifi connected" but now shows how much data is/has been used. Is that ok or is it not connecting in a way that we are not using data?
2. What are some settings that the more advanced users know about? I want to keep the system clean and performance high while adding apps/widgets that are safe. Should I force stop apps? Delete items that came with the phone?
Thank you for your time and answers.
1) To use the normal MyVerizon app, if you are on Wi-fi you have to log into you acct. to view your info, not too sure about the widget. But, since you are on Wi-fi you are not using any data from VZW.
2) You cannot "delete" much of what came on the phone. I dont reccommend "deleting" anything, espically if stock. And no, do not force close apps, the andorid system can manange most of that on its own. I also DO NOT advise using a task killer.....just my opinion.
I do however reccommend a reboot/restart every few days, just like on a computer :)
Let us know if you want/need anymore info!
