Root questions
1St question, how do you change keyboards? ROM I'm currently using only has Swype. I want to remove it and replace it with stock lg.
2nd, how do I take a program apk from one ROM and put it in another. I tried drag and drop using 7zip and it caused phone to not boot up.
3rd, it's the kernel that controls CPU speed, correct? How do I take the kernel from one ROM zip and put it in,another? Example, take playfulgod's plague kernel and put it in ldrifta's zvd no.2
1. I use Smart Keyboard but if you want stock you can just get it from the the stock Rom.
2. use Android Commander or make a flashable .zip containing that file and flash it through recovery.
3. you don't have to pull the kernel from a rom, we have separate threads in the forum with each kernel, go to the everything roots guide
Look for the stock apps in the forum and install hime. That is the stock LG keyboard
im 'almost' positive all the roms include the stock hime(keyboard).. just not selected by default, search around your phone settings more often im sure you'll find the option to switch the used keyboard..
i mean there only like 4 roms for zvd.. that i can think of.. and i know they all provide the stock keyboard..
