Quick alternative root (and unroot) method
Hawker
Android Expert
For those of you who are frightened to root your device due to flashing an insecure kernel via Odin, this method may be enough to persuade you to take the plunge.
Quick root/unroot method
As this does not flash an insecure kernel, it will not increase your counter, and hence you will not have the yellow triangle.
Note: I've not tested this method personally, but it seems ok to me.
Well this goes against everything Ive learnt so far. Nice find. :)
And no mention of Chainfire anywhere. :D
Unfortunately it doesn't install ClockWork Mod Recovery.
So either you will have to use the limited stock Recovery or fanny around with Mobile Odin and install the CF-Root kernel anyway. See here.
Might be OK if someone cannot connect to Kies or Odin or just needs root but does not want to install ROM's, Kernels, Modems, mod's, etc; I suppose.
For everything else there's always...
http://androidforums.com/galaxy-s2-...t/482994-rooting-galaxy-s2-dummies-guide.html
Could I use this method to root then flash siyah kernel or neat room in clockwork recovery?
The standard Nandroid Recovery has an "apply update" option so I see no reason why you can't do this.
Personally I would always use chainfire's method highlighted in ironass' guide, but I'm just making people who may be a little tentative flashing via Odin aware of this alternative method. If your main reason for rooting is to allow you to run rooted apps from Google Play, then this method is a viable route to root! :)
