Help "Quick Contacts" help
woodjer
Hi guys--
Sorry if this is a dumb question...I have had my Atrix for less than 24 hours and I'm not sure what to call my issue. Anyway, here goes...
On the "Quick Contacts" buttons (the four blue silhouettes on the first screen to the right), how do I delete/edit what I've chosen there. I was playing around with it last night and added my wife with options to call, text, and Facebook. I've decided that I don't need/want the Facebok option but can't figure out how to delete that option. I figured out how to resize the square, delete the "quick contact," and add an option...but still not sure how to delete just the Facebook one without starting all over.
Also, in messing around with it, I accidentally added someone that I don't need. I know how to delete it but then I'm wondering...how do I add another "quick contact?" Or am I down to just three then?
So far, I'm loving the phone. Just trying to figure out all the tricks and stuff before messing with to much of the look.
Thanks!
EDIT: Figured out a workaround, at least. I deleted the contact and then re-added it from scratch. Also, figured out how to add a new one. For those that aren't sure how to do that, Long tap (touch & hold) the home screen->Motorola widgets->Contact quick tasks->Select contact and quick tasks. Still doesn't allow me to just delete one quick task but at least it solved the issue I needed to address.
